Re: Plugs Full of Carbon
Posted by Bama Binder on August 18, 2000 at 18:57:34 from (63.10.120.138):
In Reply to: Plugs Full of Carbon posted by Patrick Graham on August 18, 2000 at 18:27:27:
The plugs being full of carbon is an indication that the engine is running rich. If they were oily I would say the engine is burning oil, but you didn't say that was the case.
Running the tractor with the choke on could be a cause of the plugs fouling, but it might not be.
I would suggest replacing the plugs with Champ D21s (or equivelent) to start with...they are hotter and will resist fouling. But I still think you have a problem in the carb. You have gas to the carb, but do you have gas into the carb venturi?? I suspect a blocked main jet.
If you haven't pulled the carb apart, I still think you need to do that. You may want to have at least a basic rebuild kit available if you haven't replaced any seals/gaskets.
I have rebuilt carbs for Cubs and Super Hs with basic kits because all the parts were in good shape and it isn't hard to do and it makes a world of difference. Good luck and report back...
Regards..BB
Post A Followup
: Re: Re: Plugs Full of Carbon
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
