Re: Carb choke lever leaks
Posted by Bob M on September 10, 2011 at 08:55:47 from (69.207.87.100):
In Reply to: Carb choke lever leaks posted by Dennis Stuhr on September 09, 2011 at 22:53:14:
As the others mention it's the bowl overfilling with gas. Things to look for/correct:
1 - Float level set to high.
2 - Bit of trash caught in the needle valve, or possibly a bad needle valve/seat.
3 - Pin hole or crack in a float. (Float is "waterlogged" with gas and has sunk.)
4 - Worn float pivot or bent float bracket. Causes the float to rub/bind against the bowl wall.
