Re: pulling my hair out-49 M
Posted by old on September 10, 2011 at 18:41:54 from (209.86.226.27):
In Reply to: pulling my hair out-49 M posted by dakota7088 on September 10, 2011 at 18:37:35:
Sounds like when you installed the carb you did not line up the gov. to carb as in should be and if wrong funny things happen. You need to have the parts in the right place of it will not run as it should.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
