Re: oil in anti-freez
Posted by Janicholson on September 10, 2011 at 20:45:41 from (67.72.98.45):
In Reply to: oil in anti-freez posted by grantl on September 10, 2011 at 18:20:05:
The oil passage to the valve gear on the head goes through the gasket. If leaking there it will put oil in the coolant.
Cracks in the block through an oil passage and into the water jacket can do it (less likely on that engine)
The sleeves are dry so it is not at all likely to be sleeves.
Combustion gasses getting into the coolant from a cracked head or bad head gasket will put what appears to be oil in the coolant. Jim
