Re: Clutch Replacement on Farmall A
Posted by El Toro on September 11, 2011 at 04:28:23 from (108.3.225.100):
In Reply to: Clutch Replacement on Farmall A posted by dmiller on September 10, 2011 at 18:15:48:
You need to support the rear of the tractor as it will tip backwards when you pull the engine. I used a block of wood about 12 X 12.
You need a good hoist to support the engine and once you remove all the bolts you probably need to wiggle the engine to get it oof the dowel pins. You may need a helper to pry the engine off the dowels. If you don't feel comfortable find a shop to do it. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
