Maybe the quick attach loader frame. I mostly just use it for lifting heavy objects or pushing snow it was a trip bucket frame. Since it has single acting cylinders I have a valve mounted on it that stays with loader when off tractor. I just run it of one remote valve on the tractor, you can see the unpainted bracket and rod I use to hold the tractor remote in engaged position when using the loader. When loader is not in use the quick couplings on tractor valve can be used for other things. Primer painted frame work down lower supports loader frame and rear hitch from the swinging drawbar anchor holes. Everything is not pulling or pushing soely on the axle housings that way.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
