Re: Lambert disc brake replacement
Posted by Haas on August 19, 2000 at 06:48:45 from (129.37.117.167):
In Reply to: Lambert disc brake replacement posted by RandallConner on August 18, 2000 at 19:47:40:
I have an MD with those disc brakes. The local clutch and brake shop relined the discs for me for $22 each. That's $88 total and the brakes work great. I bet you can't convert back to the band brakes for that. Keep the disc brakes! It makes your M something special. If you decide to change them out, send me an E-mail, because I need the cone shaped spring that is on the inside of the brake. One of mine is missing. The brake still works, but that brake feels different than the one with the spring. It must be there for a reason.
Post A Followup
: Re: Re: Lambert disc brake replacement
