Re: A - wiring and battery Question
Posted by Janicholson on September 12, 2011 at 11:06:53 from (199.17.6.77):
In Reply to: A - wiring and battery Question posted by Charlie Blink on September 12, 2011 at 10:38:36:
This will help.
The Kill switch is actually an ignition switch. it supplies voltage to the coil. It should only control the coil supply, no other components should be in that circuit. The cutout relay in the voltage regulator (if it is equipped) or the cutout relay (stand alone) with 4 position light and charge control switch, Eliminate battery drain when stopped.
Which do you have 3 position Light sw, or 4 position, (or if you know, if it is VR, or cutout)? Jim
