Farmall Tractors Discussion Board
Re: 650 diesel head
Posted by Harold H on January 06, 1999 at 18:06:24:
In Reply to: 650 diesel head posted by markw on January 06, 1999 at 17:49:01:
Mark,
The Super WD 9, I 600, I 650, and later TD 9, all used the same 350 cu in engine and the heads will interchange. There might be some slight difference in the combustion chamber but I don't think so. The WD 9 and early TD 6 used the 334.5 cu in engine but the heads will probably work as it is basicly the same engine with smaller bore. There again the cumbustion chamber is probably the only difference.
Harold H
Post a Followup
: Re: Re: 650 diesel head
