Re: First hemi??
Posted by Janicholson on September 12, 2011 at 18:21:52 from (67.72.98.47):
In Reply to: Re: First hemi?? posted by John T on September 12, 2011 at 13:11:41:
I own a Hemi!!!
Toyota purchased one or more Chrysler Hemis and reverse engineered it into the Corolla 2TC and 3TC 4 cylinder engines.
Exact hemispherical chamber, exact placement of the cam shaft (as high in the block as it would be in a V8).
Exact pushrod configuration and rockers.
Exact bore to block length.
Same wide VC with recessed sparkplug holes down the center. The oil pan parting line was changed to be perpendicular to the deck surface.
Mine is in a Austin Healy sprite which is only 4 times more powerful than the BL engine fitted from the factory and 525CC bigger. Jim
