Re: Farmall A head gasket. Or something else.
Posted by Jim Broughton on September 12, 2011 at 20:42:29 from (209.86.226.57):
In Reply to: Farmall A head gasket. Or something else. posted by scatter on September 12, 2011 at 19:56:17:
If you replace the head gasket, tappets and have the valves ground..you'll "up" the compression on those cylinders and most likely cause the engine to use more oil than before.
Try to determine the cause of the moisture and hopefully it will be an easy fix.
Best of luck.
Jim B.
