Re: ih 966
Posted by John A. on September 12, 2011 at 21:28:06 from (76.1.122.180):
In Reply to: ih 966 posted by 870blackknight on September 12, 2011 at 20:43:34:
870blacknight, As far as the tractor is concerned the usual stuff TA is it solid, the front end is it tight, or is it loose, Sloppy, or sloppy in need or a reworking, welding done on the front end!!!
Rubber, tin what kind of shape,Seat and suspension, The 3 point is it in need of a rebuild, the bushings at the lift arms!
Can you find out what is the deal with the turbo how long has it been on, How Many Hrs. since it was put on. Personally why don't you look for a 1066 in stead of a naturally aspirated 966 that was given a turbo job sometime in its life! Anyway hope this helps.
Later,
John A.
