you see the drive coupler on the pump, you need the other half that goes on the tractor to turn the pump. There is also a flat plate that bolts to the front of the trans around both the lower(pto) shaft and the center (input) shaft. The part you see there bolts on to the plate and around where the bearing cover on the ft of trans for the pto shaft was, you must remove it to install drive and then the pump assy. I would say the flat plate is a reinforcement. I will try to get more pics this weekend and put up a new post.The other half of the drive coupler takes the place of the nut that is currently on the front of the pto shaft behind the cover.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
