Re: internationalsuperatractor
Posted by JRSutton on September 13, 2011 at 04:33:10 from (75.130.109.233):
In Reply to: Re: internationalsuperatractor posted by Janicholson on September 12, 2011 at 18:53:52:
That sounds about right to me.
Here in the northeast at least, if it's painted "good enough" red you can add on a couple hundred dollars to those numbers, painted pretty red, a few hundred more
Then work down from there
Check for very sloppy steering: -$100
12 volt conversion - I consider that a negative, but many consider it a positive. I'd go -$100 for that.
Check the gas tank, make sure it's not rusted out, if in doubt -$100
Turn the lights on when starting it, if they dim way down while cranking, you could need a new battery -$100 (if the lights don't work at all - $100)
etc etc.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
