Re: Cub engine compression
Posted by Andrew Z on September 14, 2011 at 06:03:30 from (64.252.119.221):
In Reply to: Cub engine compression posted by Farmall 50462 on September 14, 2011 at 03:07:49:
Should be in the 120-130 psi range. If your below 100psi then your going to start having problems.
Andrew
