Re: Clutch problem - Re-posted -
Posted by Janicholson on September 14, 2011 at 07:59:13 from (199.17.6.115):
In Reply to: Re: Clutch problem - Re-posted - posted by Janicholson on September 14, 2011 at 07:17:01:
Because you can see it (photo) you should be able to see the PP disk move rearward, freeing the disk. It should move nearly an eighth inch total. With the clutch blocked down fully, turn the engine and watch the disk for uniformity of free clearance. If it varies around the circumference as you watch, the disk is warped ! Jim
