Re: Clutch problem - Re-posted -
Posted by Curt Cooke on September 14, 2011 at 08:48:23 from (64.186.50.66):
In Reply to: Clutch problem - Re-posted - posted by Goodman on September 14, 2011 at 05:35:57:
Just a thought. I once had the same problem though I was putting a different engine in the tractor. All new everything. I could not get the clutch to release to my satisfaction. I discovered that the pilot hole in the crankshaft was not drilled deep enough (it was a combine motor I put in a B Farmall) and the transmission input shaft was bottoming out in the end of the crank. It was not off by more than a few thousandths of an inch but enough to cause trouble. I resplit the tractor and ground just the slightest bit off the end of the input shaft. Problem solved.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
