Wilks54 said: (quoted from post at 08:36:56 09/14/11) As others have said, 3/4" coarse, I believe. The back of the head was tapered to help line things up and firm up the attachment, but I would think you can get the job done with a regular bolt and a lock washer if needed.
The mount on the cultivator was "double drilled" with a hole large enough to fit over the bolt head, then slid to the smaller 3/4" hole which was countersunk to match the tapered back side of the bolt head. I'd bet the bolts are still available from a dealer. If I remember right, one end of the wrench that came with the tractor fit the bolt head.
This post was edited by IH fan at 08:59:05 09/14/11.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
