Re: Tire inflation
Posted by old on September 14, 2011 at 09:59:44 from (209.86.226.54):
In Reply to: Tire inflation posted by Shawn Osborn on September 14, 2011 at 09:43:19:
Air can be added to them no matter where the stem if with or with out fluid but if they do have fluid in them it will work better if the stem is at the top that way you loose not fluid and that also helps save rims form rusting due to the fluid being a slat solution
