Re: Clutch problem - Re-posted -
Posted by rustred on September 14, 2011 at 10:37:29 from (74.200.18.156):
In Reply to: Re: Clutch problem - Re-posted - posted by Goodman on September 14, 2011 at 09:11:04:
the splines on disc and shaft are to be installed dry. NO grease. if that grease flys into the disc and gets on flywheel or pressure plate surface it will act as your describing. ever have a leaking rear wheel seal on rear brakes? that oil on brakes makes wheel lock right up. same deal here on clutch.
