Re: International 400 rear wheel bearings
Posted by pete 23 on September 14, 2011 at 13:00:21 from (74.32.234.149):
In Reply to: International 400 rear wheel bearings posted by Dean Hoodenpyl on September 14, 2011 at 06:44:37:
Drain, pull pto, remove bolt on bull gear, pull wheel and end cap, devise a threaded bolt and some spacers between axle and turn axle while holding bolt, pushes axle right out. Then you can move bull gear over far enough to work inside to get inner bearing out. Little harder to put axle back into bull gear but done a ton of them over the years, alone. If inside has flat roller bower bearing it will require more caution on assembly.
