it might break free or might not, i had to resplit one once and found that the trani shaft tip was scored(not sure what caused that)poss previous pilot bearing failure. now i always check to make sur the bushing will rotate smoothly on tip of trani shaft first. also saw a friend not drive a bushing all the way home on a truck and the trani shaft shoulder actually contacted the the bushing...had to split that again also, uuuugh.. after starting the tractor in a higher gear clutch depressed as you discribed try popping the clutch and it might break free...
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on
... [Read Article]
Latest Ad:
[More Ads]
