Posted by Indiana Ken on September 14, 2011 at 17:11:52 from (66.249.235.212):
In Reply to: Tire inflation posted by Shawn Osborn on September 14, 2011 at 09:43:19:
For fluid filled tires the pressure should be checked with the valve stem at the top, to eliminate/minimize the effect of the fluid on the pressure reading.
A column of water 2.31 feet high equals a pressure of 1 Psi. Therefore, if the valve stem is at the bottom, the pressure gage will read the air pressure plus the fluid head pressure. Water weights 8.33 Lbs/Gal and in the case of calcium chloride solutions the additional solution weight also needs to be accounted for. For example, with the valve stem at the bottom and checking a 38" tire filled to the top of the rim with a calcium chloride solution weighting 13 Lbs/Gal the fluid head pressure will be: [38In/12In/Foot] divide [2.31 Foot/Psi] times [13Lbs/Gal/8.33Lbs/Gal] = 2.1 Psi.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
