Posted by old on September 14, 2011 at 19:44:57 from (209.86.226.32):
In Reply to: 560 stuck clutch posted by jmducks1 on September 14, 2011 at 19:35:13:
#1 block the clutch pedal down for a few days then give it a try. If that does not work and you have it out in the open start it in as high a gear as you can and take it for a drive but only if you can do so safely. If that does not work pull the starter off and spray the clutch with brake cleaner spray and turn the engine over a little at a time so as to get the whole clutch. Do that with the pedal blocked down. Not uncommon to have that happen to a tractor and most of the time one of those will do the trick
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
