Re: Interesting eBay find...
Posted by steve_in_mo on September 15, 2011 at 07:03:09 from (64.45.253.121):
In Reply to: Interesting eBay find... posted by IAtractorKid on September 15, 2011 at 04:31:01:
Sorry. It's a good job but not factory. The mechanical parts are known to be compatible. You can put a 560 engine in an M if you use the 560 frame rails and weld a couple hood pieces together.
The toothed belt drive for a live hydraulic pump is farmerized and the welding on the frame rails and the underside of the hood is too. IH could have rolled out a custom hood and built longer frame rails instead of welding on to shorter pieces.
