Re: 560 stuck clutch
Posted by RedRoundhead on September 15, 2011 at 07:10:42 from (24.106.38.186):
In Reply to: 560 stuck clutch posted by jmducks1 on September 14, 2011 at 19:35:13:
Remove the clutch cover underneath, and check all three release levers/fingers. the pins tend to wear an oblong hole in the lever, which does not allow full cluth disengagement. You can patiently adjust them. Watch your fingers!
Best of luck.
