Re: Where could I find a diagram for the M/Super M hydrau...
Posted by Mike1972chev on September 15, 2011 at 10:29:31 from (75.149.81.173):
In Reply to: Re: Where could I find a diagram for the M/Super M hydrau... posted by nh269 on September 15, 2011 at 10:05:56:
I am a little uncleaar on what you are doing here?
Are you using the old "belly pump" reservoir as you oil supply for your live pump on the engine?Or,do you have the reservior that goes under the fuel tank?9or some other remote reservoir?)
If you can tell me EVERYTHING you are trying to run with your "live pump",I can probably show you how to plumb it up.
