Re: Bent push rod on an A
Posted by glennster on September 15, 2011 at 14:55:48 from (76.224.6.58):
In Reply to: Bent push rod on an A posted by Fullers Farmalls on September 15, 2011 at 14:22:02:
check the valve to see if it is sticking. if everything is ok you can pull the rocker shaft off (couple bolts) replace the bad push rod and just re-set all the tappets.
