Re: 6 Volt Charging System
Posted by Janicholson on September 15, 2011 at 19:29:09 from (67.72.98.45):
In Reply to: 6 Volt Charging System posted by Brad Sprague on September 15, 2011 at 19:03:53:
The regulator is intended to do just that. Checking the battery voltage with a charged battery, and the engine at 2/3 throttle, a meter across the bat terminals (meter with needle is best for this) the volts should read 7 to 7.4 volts. If it is the charging system is great. If down near 6.3, it is not OK. Make all components shiny to ground and proper connections at wires if no charging.
