Re: Re: 450D oil
Posted by Redfan on August 20, 2000 at 03:20:39 from (203.87.53.9):
In Reply to: Re: 450D oil posted by Jon....Another thing on August 19, 2000 at 18:11:10:
Yes John, same oil in pump. One tip you may or may not have picked up here before, when shutting the motor down, allow it to idle back for a good while if it is hot. When you think it has cooled sufficiently, snap it over to petrol mode and turn off the petrol tap. This allows the auxilliary combustion chamber to dry out, making it easier to start next time. Once the motor is stationary, snap the levers back over to diesel mode, this seats the starting valves which allows them to cool at the same rate as the head, thus preventing them from warping. It is a good system, if it is treated properly, it will be very good. Regards, Redfan.
Post A Followup
: Re: Re: Re: 450D oil
