Posted by Janicholson on September 16, 2011 at 11:43:46 from (199.17.6.65):
In Reply to: Neutral safety for H posted by David G on September 16, 2011 at 11:14:54:
The switch would be on the deck and vulnerable if done in a reasonable method. If the deck is removed, and a linked oil proof micro switch setup was placed on each shift rail, that would work, but be way involved. A far better approach (opinion) is to put a battery shutoff switch on the Bat Wire. This would be a Key switch, not just a lever. Then there would be no operating the tractor at all without adult supervision. The rod starter mechanism is going to work even with an ignition cutoff, thus running others over with un intended consequences is not prevented by a Neutral Safety switch. If a relay start system with a Key switch was used. That would also be able to be interlocked with great difficulty (as above) but would prevent all movement Very non stock. In my opinion the Battery shutoff solves all issues without being difficult or perverrting the originality of the tractor. Kids should never "play" on them anyway. Very careful education and caution information will make the most impact, and be strategic in the long run. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
