Posted by Owen Aaland on September 16, 2011 at 15:20:31 from (216.47.32.147):
In Reply to: Neutral safety for H posted by David G on September 16, 2011 at 11:14:54:
The switch for a I-444 would probably be made to work off the clutch pedal. It is a rotary switch, normally open, with a spring loaded arm that contacts the pedal. As the pedal is pushed down the spring moves the arm to rotate and close the contacts in the switch. I think that switch could be mounted below the platform so it would be out of the way.
The switch is the same that is used on a 58 Chevy C60 truck for a brake light switch.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
