Farmall 350 Diesel No Fuel?
Posted by kelly mt on September 16, 2011 at 19:40:25 from (216.14.234.237):
I just brought home a Farmall 350 Diesel. It has sat outside for 7 years never started, earlier post. Well it's in the shop now and I can't get any fuel at the injectors. I have fuel in the tank, drained the separator to clean fuel, bled the filters and have clean fuel flowing freely at the pump inlet. I cracked the injector lines at the injectors and cranked the motor and get no fuel. Also no white smoke when lines are tight. The shut down lever moves freely as does the throttle. This IH motor has a Rosa Master pump. Any ideas? Thanks PK.
