Posted by Owen Aaland on September 16, 2011 at 21:27:27 from (216.47.32.147):
In Reply to: live pto on 300 utility posted by Truckmaster100 on September 16, 2011 at 20:42:00:
Your choices are a transmission driven PTO or an Independent PTO. The same choices applied to the 450. Whether or not you can use it depends on what parts are already in your transmission. If your tractor has a TA there is a good chance that the IPTO will be usable without changing much. It you do not have a TA then most likely there is no provision made for anything other than the transmission driven PTO. If you were to list the suffix codes after the serial number on your tractor I'm sure someone will be able to tell you what your tractor has for PTO provisions.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
