Re: live pto on 300 utility
Posted by Wardner on September 16, 2011 at 21:33:49 from (4.154.237.132):
In Reply to: live pto on 300 utility posted by Truckmaster100 on September 16, 2011 at 20:42:00:
First of all, independent PTO means live PTO. They are driven from the spring cover on the main engine clutch. That gets solidly bolted to the flywheel. The IPTO can be engaged under any condition. It"s independent, after all.
The auction is for a clutch type IPTO. There is a multi-disc clutch inside the PTO attachment. Will not fit 300 Utility as the RPM will be affected. They use either a planetary IPTO or the old style transmission driven PTO. The suffix letters after the digits in your serial number will tell us how your tractor is configured.
Should also point out that IH did not make a 450 Utility.
