Posted by John A. on September 16, 2011 at 22:10:32 from (76.1.122.180):
In Reply to: Stuck Piston posted by Jim Paterson on September 16, 2011 at 19:56:51:
Jim, This method will have that piston freed up in relatively short order. 1st...Clear area of all combustibles. 2nd...Remove gas tank from tractor if it is not already off 3rd... roll tractor outside to ensure you do not get the blding on fire 4th...fill the cylinder up to almost full of DSL, add a splash of gas, set mixture on fire. 5th...Drink a cup of coffee, Coke, adult Beverage and let the fire burn itself out. 6th...If the volume of the cylinder is greater than 1/2 the stroke chances are the piston will just move on up as you drive the piston out. If the volume is less than 1/2 the stroke you may need 2,3,4,+ burnings to generate enough heat to pop the rust and let the piston turn loose. This method will usually save the pistons and sleeves if they are not damaged from being stuck or rust pitted. If you have questions hollar at me tomorrow @.512-577-3837.If you want to. Hope this helps. Later, John A.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
