Re: Stuck Piston
Posted by El Toro on September 17, 2011 at 04:19:25 from (108.3.225.100):
In Reply to: Stuck Piston posted by Jim Paterson on September 16, 2011 at 19:56:51:
Remove the sleeve and piston together. You can apply some heat to the sleeve to remove the piston. Hal
