Re: vacuum lift on Farmall A
Posted by Brownie 450 on September 17, 2011 at 05:29:35 from (66.43.241.198):
In Reply to: vacuum lift on Farmall A posted by Charlie M on September 16, 2011 at 15:14:17:
For the cultivator lift, the cylinder was mounted vertically on the left side front attached to a flat piece--maybe 3/4 thick by 1 1/2 wide with a bend or two. The strap bolted to the front of the block IIRC.
The plow lift had the cylinder mounted flat on the left side near the gear shift lever.
I think there may have been a cable/ pulley arrangement on the cultivator for lifting.
Been a LONG time since the plow & culti have been on the A.
