Re: 48 cub problems.
Posted by Tom Fleming on September 17, 2011 at 17:18:55 from (67.20.249.95):
In Reply to: 48 cub problems. posted by BenB on September 17, 2011 at 14:07:02:
If you followed the timing procedure in the manual, you should be fine. A quick thumbnail is as follows: #1 piston on TDC on the compression stroke. with the mag cap off, make sure rotor is pointing just before #1. mag should slip right on, with the slots lined up. Turn slightly and the impulse should click. tighten her down and you are ready to go.
Like I said, this is a brief thumbnail. If the impulse is clicking twice, then there is an issue in the impulse. Did you try pull starting it? Also, did you have the cam out? You may be timed correctly to the govenor/mag, but is the cam timed right to the crank? Worst case, take the head off, and watch the valves and pistons. Also note the timing mark on the front pulley.
Keep us posted and let us know the progress.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
