Posted by CNKS on September 17, 2011 at 19:03:10 from (216.144.104.128):
In Reply to: 560G Timing help posted by matt_in_michigan on September 17, 2011 at 12:03:22:
You should be able to get #1 at TDC by shining a light into the spark plug hole. But, your distributer has to be aligned with the oil pump. I don't have the details as it has been a while since I assembled my 460HU. It is explained in the engine manual, may be in the I&T manual too. Also there are marks on the crankshaft pulley to be used with a timing light once you get it to run at TDC. You shouldn't have to remove anything to see them, although they are hard to find and clean so you can use the light.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
