Posted by JRSutton on September 18, 2011 at 05:02:25 from (75.130.109.233):
In Reply to: 48 cub problems. posted by BenB on September 17, 2011 at 14:07:02:
It does almost sound to me like it's 180 off - as somebody else mentioned.
But if you're sure it's not...
I'm not clear on what you actually mean by kicking back. It COULD be that you're trying to get it so exact on TDC that you're actually slightly ahead of it, and sparking before the piston's there. Don't be afraid to err on the side of being past TDC. That'll have the added benefit of preventing broken bones should you ever need to hand crank it!
I've seen people try to get super precise with the timing, and it's worth remembering that these things aren't race care engines. A degree or two here and there isn't going to matter in the least.
So assuming everything's ok on that side, I'd spray a little starter fluid into the carb while starting. If it runs at all, that's a pretty good indication that your timing/ignition is ok, and you might want to focus a little more on the carb.
Not 100% foolproof, but if you're not having luck now with it, it can give you an "educated guess" on where to go next.
PS. You said you got it when you came back from afghanistan. Assuming you were there in a military role, I'm sure I speak for everyone here when I say thank you for your service.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
