Re: Overhauling Farmall SMD Dumb Newbie Question
Posted by Nebraska Kirk on September 18, 2011 at 06:38:56 from (207.91.4.138):
In Reply to: Overhauling Farmall SMD Dumb Newbie Question posted by ralph1111 on September 17, 2011 at 17:26:09:
Like others have said, you need to use a micrometer and measure the main and rod bearing journals to determine if they are worn. Here are the specs:
Connecting rod journal diameter: 3.2475-3.2485
main bearing journal diameter 3.7475-3.7485
Maximum permissible main bearing clearance before reconditioning: .009"
maximum permissible journal out-of-roundness before reconditioning .004"
Main bearing running clearance: .0018-.0048
Connecting rod bearing running clearance: .0017-.0047
Maximum permissible connecting rod bearing clearance before reconditioning: .007"
