Re: sediment bowl twisted off
Posted by old on September 18, 2011 at 07:42:30 from (209.86.226.27):
In Reply to: sediment bowl twisted off posted by joe joe on September 18, 2011 at 07:05:56:
A good and I do not mean a cheap hard ware store common run of the mill Easy out will most likely do it. Or if you remove the tank and flip it up side down and use a drill bit that might push it into the tank then you could shack it till if fell out of the gas cap hole. Or if you have one one of those hole reamers would also probably work
