Posted by CNKS on September 18, 2011 at 08:53:08 from (216.144.104.128):
In Reply to: TIre size for rim posted by Dave H (MI) on September 18, 2011 at 08:05:01:
Remove the tire and measure from the inside of the lips that the bead sits on. You can safely go 1 inch wider than that measurement and the tire will fit ok. The size may be stamped on the inside of the rim, if you are lucky. Ideally the tread width should be the same as the rim width. But a 10-36/11.2-36 on a 9 inch rim will be ok. If you really have an 8 inch rim you need a 9-36/9.5-36. In modern terms 9 inch tires look a little narrow -- I have a C with the old 9-36 tires on it, will probably replace with 11.2-36, but I will need new rims. 12.4's are simply too wide for that tractor unless you are into pulling or something.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
