Re: Farmall H Will Not Start
Posted by Harold Evans on September 18, 2011 at 13:42:19 from (69.136.4.122):
In Reply to: Farmall H Will Not Start posted by D.W. Pirkey on September 18, 2011 at 12:42:52:
Can we assume that you checked the battery to see if it had water in it, too? You will need some electrical juice to keep the tractor running unless you have a magneto, of course. Can you tell us more about what is on your tractor?
You might also check the gas flow again. Rust in the tank can cause the tractor to run until the carb bowl is empty, then stop, and then be able to be started once again after the bowl fills up at a very SLOW rate of flow. Frustrating, to say the least.
There are other possibilities. You'll have to check them off one at a time. Then you'll know where the problem was in the first place.
