Re: Stumped - Magneto Timing
Posted by gene bender on September 18, 2011 at 15:47:05 from (207.177.56.78):
In Reply to: Stumped - Magneto Timing posted by Randall McClenahan on September 18, 2011 at 09:43:54:
If the engine ran at all the timing is ok or it wouldnt even start. If you turn it over with the crank the rotor will stop at #1 position then fire remember it did run so the timing is ok or it wouldnt have started. There is no timing of the mags if the rotor is lined up on the tower when it fires its good to go and yours did run a little.
