Rhill is correct. If it has been left up for long periods the small leakage into the top of the cylinders has collected and spews. Use rags over the tops and slowly lift to purge the oil. (or take them apart to bleed the oil out of the top.) Then expect this to happen once in a while, (always set the bucket down when not using it!) If it gets worse, or is bad enough to make this a monthly routine, The cylinders will need new piston seals an checked for rust pits in the bore. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
