Re: Overflow fuel line leaks
Posted by Jimb2 on September 18, 2011 at 19:58:16 from (174.115.9.174):
In Reply to: Overflow fuel line leaks posted by Richard from NY on September 18, 2011 at 15:45:23:
Hi Richard, I assume you are talking about the return line on top of the injectors? Only solution is to replace complete return line. The older ones had a braided flex line, the newer ones have a composite material. They always leaked where the braid was joined to the fitting that was connected to the injector. Also would leak more in cooler weather.
JimB
