Re: Neutral safety for H
Posted by NoNewParts on September 19, 2011 at 09:59:33 from (67.240.146.222):
In Reply to: Neutral safety for H posted by David G on September 16, 2011 at 11:14:54:
thinking out loud here...........
two stage safety switch
in the heavy cable to the starter
wire in a cut-off relay
mount the relay activation wire up
by the steering wheel, so you can only reach it from the seat.
connect this wire to a button you have to hold in.
power is now available at the starter with button held in
to activate starter, wire in a Ford "8N" starter solenoid which
uses a ground wire to activate.
make a insulated bracket for the ground wire,
and mount it to the steering post, exactly inline with the shifter
when it is in neutral.
to start, hold down steering wheel button to supply power to
the starter, push shift lever all the way to the right when in neutral.
When the shifter makes contact with the bracket, it will supply the
ground and the tractor will turn over.
When the tractor starts, let go of the push down button on
the steering wheel. Then the shifter setup will not be 'live' and you won't engage the starter accidentally when shifting
I'm going to rig up the shift lever/Ford N solenoid setup only
on a Super H that I never used the high gears on,
so it won't start unless in neutral and I don't have to bend over so far to reach the stock 'pull' rod
for the 2 stage setup, you will need to connect the tractors normal wiring to the battery side of the relay of course
This post was edited by NoNewParts at 10:09:33 09/19/11 3 times.
