Re: M locked up
Posted by Janicholson on September 19, 2011 at 11:17:48 from (199.17.6.77):
In Reply to: M locked up posted by JohnDeereGreen on September 19, 2011 at 10:38:03:
Put it in 5th gear and rock the tractor back and forth hard. If the fan moves at all, it is probably not the rings. Pull the pan and valve cover. and look for obvious grief. If the crank can be turned back and forth, and the valve train does not move, the cam gears may be toast. If it has a hydraulic pump in front of the distributor, there is a good probability of failed gears.
Jim
